Quick question for the guys that runs solar system. I can get a 48v 5kv inverter that runs AC charger and Solar charger mode. The solar charging rate is 50A with min Solar voltage of 36VDC and max 105VDC.
My question is, is the best option to go for 36v solar panels and run them parallel to get 72v or must i check to get panels that is 24v? If i remember correctly, the panels is 365 watts . I just need to check how much Watts the inverter can handle.
Battery's side I will sort out.
