advice for a general audio setup
djiceman
JHB
Hi All
Ive been lurking around for awhile and its finally time to post. I need some direction for a new setup(entry level) which will be used daily for tv, youtube videos/music and weekend movies.
So its a very generalist system which I also hope will be my hdmi input handler.
The lounge is ~35sqm and currently I make use of a creative a220 2.1 speaker set(plugged into the tv using 3.5mm). I particularly hate the mismatch of volumes in movies/series(showmax/dstv, other providers) where vocals are soft and all action sounds are loud. I have to keep the remote in hand to constantly adjust the volume.
Im not sure if I need to future proof myself for extra features(atmos, etc), so this im still on the fence.
Heres the system Im thinking off(its in a kit form on special at some stores):
Boston Acoustics CS260II fronts
CS225CII centre
CS23II bookshelf
CSSUB10II sub
The amp, im in a mixed bag around the Denon x540BT / x1400H / Onkyo NR656.
Do you guys think this im going down the correct road?
Which combination(im open to other systems) do you suggest will fit my needs?
Thanks
