Advice/help needed from the DIY speaker guru's
Tobes
In a beautiful place...
Guys I have a set of these entry level Yamaha speakers. I would like to know if it's possible/viable to upgrade them with better, decent drivers and matching cross-overs using the same box - it doesn't have to be Yamaha drivers, it can be any decent recommended brand. It has a base port of 65mm at the back as per pic. The specs and sizes are included below. Can it be done? Is there someone that can recommend drivers, cross-overs, box mods, box strengthening, etc?
No yellow cones please  :point:
Specs:
2 way base reflex system
Drivers:
woofer: 16cm (6-1/2") cone type x 2
Tweeter: 3cm (1") soft dome type
Nominal input 50W
Maximum input 180W
6 ohms
Frequency response 37Hz - 30kHz (-10db)
Sensitivity 88dB / 2.83V, 1m
Dimensions (W x H x D)
200 x 1030 x 362mm (7-7/8" x 40-1/2" x 14-1/4")
Weight 11.2kg
