Hi Gents,
I have hooked up my TV via optical cable to a Marantz SA KI Pearl Lite CDP (input) and have taken the audio out to a Plinius Hautonga via a decent quality RCA cables.
Problem is that there is a crackling noise when I stream from Youtube.
The CDP plays CD's perfectly and music stored on a USB also sounds clean.
I have swopped out cables and the crackling noise is still there.
The only other trouble shooting that I need to do is swop amps, but if I connect the optical cable directly from the TV into a Rotel RA12, there is no crackling noise.
Any and all advice will be appreciated.
Regards,
Pres.
Regards,
Pres.
