Hi guys
I'm busy with an old amp and I've found that some of the
Solder joints on a few boards have melted and are now
Touching causing a short. I suppose this is because of years
Of use and heat. I have a soldering iron and one of those solder
Sucker things but its not removing all the solder. Most of the
Solder is being removed but there's a thin layer still on the
Board that doesn't seem to come no matter how much I heat
It and use the sucker.
What would the best way be to completely remove all the solder?
Vishen
Vishen
