Audio Advice for a Jukebox Project
Achilles-ZA
Durbanville
Howsit guys
Great site you got here, cant believe i missed out on this before but here goes.
Im in the process of building a jukebox for home use, it will be powered by a computer etc etc, only planning left is the audio side of it.
Now i used to be in car audio and thought about using car drivers/amps for it but started reading about issues with power supplies, not as efficient etc etc etc. I started browsing PQSound and a couple of hobbyshops to see what amplifier boards is available.
What i need(or that i think i do) is:
2 x Tweeters & 2 x Mid/Full Range drivers, these will be built into the jukebox below the screen and will produce majority of the sound , then i was thinking of building a seperate enclosure/speaker box with a subwoofer that will stand next to the jukebox to give some bass.
So what do i need? the input level will be from the pc sound card, but after that i dont quite know what will be good options, so any advice will be appreciated. From what i have seen on PQsound online store there is pre-amps i might need, main power amplifier (or maybe 3 since there is mostly mono boards available), powersupplies (ac-dc dual output & single output) and then speaker protectors & crossovers.
Will somebody please nudge me in the direction i need and links to products will be a bonus.
Thanx in advance
