Audio Technica 95E cartridge upgrade to Rega Bias 2 or Elys 2?
irengineer
Centurion
Guys, I have a NAD 533 turntable (Rega P2 OEM) that was fixed and serviced by Croak. The deck is fitted with the RB250 tonearm and an Audio Technica AT95e cartridge. I am thinking of upgrading (if it is indeed an upgrade) the AT95e to a Rega Bias 2 or Elys 2 cartridge. I do not have VTA spacers for the tonearm, so sticking with Rega cartridges will save me from fiddling with the deck's VTA adjustment. Does anybody have an opinion on this as an upgrade path? I can get the Bias for around R 1300 and the Elys for R 2100.
Thanks!
