- Joined
- Dec 2, 2009
- Messages
- 2,630
- Reaction score
- 12
Usually get good advice here, so thought I'd here too.
I'd like to permanently wire in a compressor to my vehicle - behind the passenger seat (2 seat 4x4)
Basically want to run cabling from battery to compressor - then while I'm at it, but in an extra 12v socket in the rear for a fridge (compressor and fridge won't be used at same time)
So far I have
10m 10mm cable
3x harrison plugs (one for compressor, one for 12socket - and one for clamps so compressor is still usable when removed)
8mm lugs for battery
Still need to get a fuse for the battery side. (thinking 50AMP ?)
Do I need fuses again at the compressor and 12v socket?
So far I have
10m 10mm cable
