B&O Beovox 2600 fixer-upper
Gareth80
Sunward Park, Boksburg
Got these from Fasor (thanks Fasor).
Just the cabinets. There are no crossovers, Driver or tweeters (going to have to find some.
Doubt I would ever be able to source the original components. Been looking at some options on PQSOUND.
Let me know if you have any recommendations on some tweeters drivers and crossovers.
Some pics of what the cabinets looked like before,
After getting the black spray paint off and some sanding,
Some chunks of veneer of on one of the cabinets... Not sure how to deal with that or hide it,
Issue where the edges are pulling away (doesn't seem to be the veneer but the whole side). Not sure if I should put some glue in there and then clamp the together to see if the gap would close or use some wood filler? That would probably look crappy.
Some more sanding and after applying some "Howard Restor-A-Finish -Neutral"
Sent from my D6603 using Tapatalk
