B&W 704 - Are these lean or is it my ears or system matching?
PAPPA3
Randfontein, West rand
Been playing around with these.  They are on spikes.  Compared to the CDM-7NTs I had I have to admit they sound a bit lean.  Initial impressions are that they are power hungry and less forgiving with bad recordings than the 7NTs.  I'm using more or less the same sources: Yamaha RX-V1900 into a Rotel RMB1066 (150watts @8ohms).  I know that psychologically I need time to adjust to the change.  I'm starting to think the Rotel may not be such a good match, but perhaps the speakers need a bit more time to run in.
But I thought maybe others who have experience with these speakers can comment.  Bass is there, but I'd describe these speakers more as controlled and precise than warm and emotional.  I removed the foam bungs and moved them closer to the wall, but bass is still less than the CDM-7NTs.  Their strengths (my impressions so far) are that they are more articulate - they are at pains to place things correctly in the soundstage and stop and start parts of the music accurately.  There is a decent amount of transience heard, but I wouldn't describe them as overly revealing
