Rodney_gold
R.I.P. 5 June 2018
Having quite a few cars I don't drive that often, I have retrofitted just about all of them with battery cut off switches.. which do work (If you remember to switch em off) but have a BIG downside in that all info is lost , like radio presets , clocks , ECU learning, adaptive suspension learning , electronuic gearbox klearning and all sorts of other stuff like seat memories and so forth..some radios require a code to restart and it all becomes fiddly...
So I decided to invest in the best...my 2 old battery trickle chargers are making buzzy noises and have either rapid or normal ranges , neither of which "conditions" the battery - so I got this (around R1000)
http://www.ctek.co.za/gb/en/chargers/MXS%205.0
In addition I bought this Jump starter/power station.... R1349 from Autozone - It's a Clarke jumpstart 1224 rebranded or vice versa...
some SERIOUS power there - like in hifi , more power never hurt...
http://www.amazon.co.uk/CLARKE-JUMPSTART-1224-VOLTAGE-STARTER/dp/B006YLYUXW/ref=pd_sim_sbs_diy_7?ie=UTF8&refRID=0ZA1N81CZ3NVT3F4EAT1#productDetails
Already used the ctek which works a charm , all batts now in tip top condition and no 50km rough driving when re engaging "learning" cycles ...
Just in case , I carry the Jumpstart in whatever vehicle I'm driving...
