Chain Saw or Pruner
santoshlv426
Centurion
Guys,
What would you suggest for garden cutting machines. Chain saw or Pruner.
I was intent on getting a chainsaw and have been doing some reading up about these. Apparently, the blade blunts after a while and is a pain to sharpen, and has to be replaced.
On that point, I've come across the Powersharp system. has anyone any expereince with this and can comment if I should get this or a standard chain saw and take it to a lawnmower place to sharpen.
I see that Ryobi sells sharpening kits.
I've no prior expereince with chain saws and will be using it to trim hedges and lopping the odd tree branch.
Choices are Tandem, Ryobi or Lawnstar.
Apparently Trimtech and Tandem are the same ??
Thanks
www.powersharp.com
