Hi All
I am seriously considering running a dedicated power supply from the DB to my AV equipment. I was thinking of running two new lines, each on its own circuit breaker and then using a section of power skirting with about 5 plug points on each line (total 10 plugs).
I need advice on the specifications for the wire, circuit breakers, plugs etc.
Any advice/suggestions appreciated.
Regards
M
Regards
M
