DIY Sub-woofer Box Build
Gerlach
A Question for the guys that's in this sort of stuff and can maybe help me.
Plans is to build a DIY Subwoofer setup for home use. Specs of the sub is:
Star Sound Digital SSW-K012-2700
2.4" 4 layer Voice Coil
Re: 4Ohm
SPL: 92db
Pe: 1W/1M
Fs: 32.9Hz
Qms: 4.2709
Qes: 0.5404
Qts: 0.4797
Vas: 2.28 cu.ft
Sd: 0.0511 m2
Power will be supply by a Velodyne Impact 12bve Amp plate. ashleym from the forum gave it to me for free to see if i can repair it and to used it for DIY build. Got it fix and up and running.
Port will face downward with the sub and build will be with 18mm MDF and a smaller box that needs to go inside at the back of the Amp plate to seal it off. (all this info and stuff will go under the DIY build when I start building it)
The question is: is the size correct of the box to spec of the sub?
If someone can check for me with there programs they use to do the maths on there box design, i will really appreciate it.
Thanks :thumbs:
Here is some info on the sizing and Hz i got from  AJ Vented Designer and WinISD
With AJ Vented Designer i added about 3l inside the box to add up for the space the box will take inside the box for the Amp plate to seal it of inside. Port length is 16cm.
WinISD
