DIY wall bracket for speakers.
Crocos
Rustenburg
I cant find wall brackets for small speakers that isnt either way over priced or simply not available before next week.
I have come up with a very basic design, something i can make easily at home with a grinder and a drill.
Is it ugly? Yes. Will it work? I dont know. Maybe.
Flat bar cut into various pieces and welded together with a simple 8mm bolt and nit through to allow me to adjust the angles.
Welding is minimal. 1st section is welded onto wall plate. And then the 2nd piece has a T-Section welded. Thats it. So 2 minor welds. The drilling / grinding will take longer.
If my math is correct, even at 10cm lengths, which this is not, it will only start sagging after 9kg weight.
Has anyone done anything similiar? Or if you did a DIY bracket please share.
Also found this method
It actually makes more sense than my design. I think.
