I know squat about these products, but I do know that I suffer from Sinus and Hay Fever. I was wondering if this would be worthwhile to install in the bedroom, but I don't want excessive fan noise (such as I get with the air-con), nor would I like brilliant lights lighting up the room at night.
I have so far looked at two units:
Solenco CF8500 Air Purifier
This is a plain and simple air purifier but seems to have an irritating blue light, which can be sorted out. At TaL at R2499.
AirZone GIAI OZONE Air Purifier
This seems a good unit and also features an Ozone Ioniser.
From the website: https://www.ecohub.co.za/shop/best-sellers/airzone-giai-ozone-air-purifier-details
3 in 1 Air Purifier - HEPA Filter, OZONE Sanitizer & Ionizer.
Most air purifiers will only kill viruses and bacteria that pass through the unit. The Airzone unit generates ozone on a timer which sanitizes the entire room. Air Purifier can be wall mounted, or stand on the floor or a table. Adjustable Ozone And Remote Control.
Can be used in conjunction with the Solenco CF8500.
Now I need to wonder why, if this is such a good product, would it need to work with the one above?
Room size is about 7 x 6 metres.
All info will be appreciated
