JNouw
After the work and input that i did on the EL 84 SET kit, I have been considering for some time to work on a Push Pull EL84 amp. In all probability it will be an integrated amp in a conventional enclosure, but still to the same high standard as the SET amp.
Power output will be 15 Watts from 2 EL84's in pentode mode, and an option to switch to triode mode, but with an output of around 5-6 Watts.
The circuit diagram is dead simple (how I like it) and will probably end up with a little tweak here and there:
[/URL][/img]
