Electrical help.
thenoizeguy
Johannesburg Broadacres
One of my transformers got moisture in it and popped last night. It is a Radiant T200C which doesn't seem to exist anymore.
Specs. Input 230V Output 11.5V 15.2A.
This was running 4 12V 50W lights running on 12 metres wires across my dining area.
All I can find at Builders is the single light 50W ones. Does anyone know where I can find a replacement ?
There are no other options on this, it has to stay at 12V  due to the exposed wires or tracks as they're called I think.
Thanks,
