Good day,
My previous car had a Alpine headunit, had it installed after I bought the car, which was able to play FLAC from USB flashdrive. Sound was awesome and I was a very happy driver.
My new car have the original factory unit. Unfortunately installing an atermarket unit is not an option as it's integrated into the dash. On top of that the unit 'talks' to the info display via CAN or some kind of protocol I can't recall now.
So I've been looking at a portable device which will be able to play my FLAC files I have on my flashdrive. Even if I have to copy it to the the said device it will be fine. I just need that awesome sound quality again. The car have a USB port, only supports MP3, and a round audio kind of plug, like the ones find on headphones. I believe the latter is for an Ipod...if I'm not mistaken.
Does anyone have any suggestions?
