• If you have bought, sold or gained information from our Classifieds, please donate to AVForums South Africa and give back.
    You can become a Supporting Member or just click here to donate.
FS - Amplifiers Fosi Audio V3 (48V) Stereo Power Amplifier @ R3,195 (sold by Faith Acoustics)
Faith Acoustics
Commercial Member
Cape Town, South Africa
"The best amp under $400" — CheapAudioMan Review.
“State of the art DACs run on highly performant silicon that when well implemented, produces the best performance we have seen. We are seeing similar development with these class D IC amplifiers. Noise and distortion is quite low and beats many amplifiers in the market.” — Audio Science Review.​
fosi-audio-v3-front-bookshelf-white-477252102637224875-82b746a2-dfcc-4b7b-945a-b6f8474cff04.png
Howzit Guys. Petrus here from Faith Acoustics, local distributor for Fosi Audio and ShenzhenAudio products.
I have been importing and selling high-fidelity budget class-D amplifiers & DACs in South Africa since October 2023, with nationwide shipping. My seller profiles:​
The V3 is a modern class-D stereo power amplifier by Fosi Audio. This budget audiophile amplifier competes on signal-to-noise ration with much pricier amps like the Marantz PM-90 (R18,000).​
V3 Specifications​
  • SINAD: 88dB​
  • SnR: 110dB (signal-to-noise ratio)​
  • THD: 0.003% (Total Harmonic Distortion)​
  • Dynamic Range: 16 bits at full power​
The 48V power supply squeezes substantially more performance out of the TPA3255 chipset than the standard 32V PSU. The previous generation TB10D left me wanting more with the standard 32V power, so I only stock the 48V version. These units come with a 24-month warranty.​
Max Power​
  • 159W per channel into 4 ohm @ <1% THD​
  • 89W per channel into 8 ohm @ <1% THD​
Peak Power​
  • 300W peak power per channel (momentary) totalling 600W​
  • 190W peak power per channel (CEA-2006/490A standard) into 4 ohm @ <1% THD+N​
  • 380W total peak power at <1% distortion.​
Inputs​
  • Stereo RCA​
Outputs​
  • Stereo speaker binding posts or banana plugs​
  • Lab Out (minijack / aux) for an active subwoofer. Note that a Lab out is not controlled by the volume knob (Pre-out is a misnomer).​
Background​
Over the last 10 years, class-D got good (the D does not mean digital). Class-D offers much higher efficiency (especially at idle) than older class-A or AB amplifiers.
Class-D amplifiers use pulse-width modulation to generate a pulse train output which is then filtered to remove high-frequency pulses. By turning on transistors only as-needed (usually MOSFETs), class-D amplifiers can achieve efficiencies in excess of 90%+. As a result, these amps are smaller, lighter and cheaper to build than their class A & class-AB predecessors.
I use the Fosi Audio V3 drive my KEF LS50 Meta speakers. They knock the socks off my old Crown K2. I also tried the budget Arylic A50+ integrated streamer + and would not recommend it (cold sound, distortion and cuts out at full power.)
You are welcome to bring your speakers for a sound test in Stellenbosch, or if you're nearby, I can come to you.
For more detailed measurements, please see Amir's measurements on AudioScienceReview.
Order online today from faithacoustics.com for only R3,195.00. Alternatively, phone or message me directly on WhatsApp: +2️⃣7️⃣7️⃣6️⃣3️⃣3️⃣8️⃣1️⃣7️⃣9️⃣2️⃣.
Thank you for your business
Best regards
Petrus Theron
CEO, Faith Acoustics
Personal Website: petrustheron.com
