Has anyone done their own sandblasting?
mafioso
I often mill very small parts from aluminium - objects with a mass of around 5g or less.
If the object has flat or chamfered edges, I usually sand them by hand which is very time-consuming and finally I may give the parts a 'chemical polish' by immersion in boiling phosphoric acid.
If there are protrusions or recesses in the part's design, this presents a real problem to get a perfect and even surface finish.
I looked a bit at various sandblasting diy sites and the media (glass beads, silica sand and walnut kernel particles) and also the health risks associated with diy sand blasting.
I believe Builders Warehouse has a diy kit. I haven't looked at it yet but web comments seems to indicate it's total rubbish.
Has anyone any experience of this type of surface finishing?
mafioso
