Hi Guys,
Had a power issue at home with the DB. Since then the receiver has no sound and no speaker icons on the display. The HDMI is fine as I Can still see picture from the sources. I've performed a hard reset as per Manufacturer website recommendation. That hasn't worked. Have any of you experienced similar issues? If so what was the fix?
Thanks,
Vernen
Thanks,
Vernen
