help value
King_Julian_S
Jhb Alberton
hi all.
Can you help put value here ?
if one has to sell as a single bundle.
just a quick guess will do. I find it difficult to put prices on old stuff and especially stuff that needs work, no matter if minor.
Would suit a "peeter pollie "  nice..
Do you think 15k is too much for all ?
Alphason Sonata (pcb Cap burnt - A Hobkirk said he will look to fix)
HR100S ARM
FUNKFIRM achromat 3mm
Cardas golden CUBOIDS myrtle
Russ andrews Kimber interconnect
AR PH2 phono(MC setup)
MC setup , can be changed internally as per manual
BALANCED AQ interconnects with AQ  RCA converter plugs
SQUEEZEBOX touch
With remote and box and manual
Monster interconnects
300B Mono's with gain control
with 8 X 300B TUBES EH
Jonathan Noble designed and built
AQ interconnects
LP CUPBOARD
Vintage type with LP racks
enough vinyl in various conditions
(Some new , like MOFI Marvin gaye , Michael Jackson, ETC..)
SONY TC630 music centre RTR
Complete with speaker cab and mike's and some reels
Orior said he could fix. Plays but only fast, so need a service
NAKAMICHI 580M
Orior could fix - motors work etc, playhead cam not lifting nice ,needs service and perhaps new belts to cam
FERROGRAPH series 6 valave RTR
orior could fix - looks like felt pads on pinchers need replacing
With cab and goodman speaker.
all valves lighting up in pre and power section
ISOPHON melody series
needs soldering drivers back to transformer XO,
ALL original and complete and working
b&o 1000 TT
Working with cart.
needs service(cleaning) and some minor screws tightened
and perhaps a new counterweight(existing looks like a crack)
Stand Sound structures 5 rack stand(solid built) can be sand filled
with spikes , and extension pole pieces very heavy
some minor scratches from heavy equipment, mainly on lower shelve
one chip, piece of wood in hand.
spinkleen Manual RCM , with liquid and cloths, used once or twice
dynavector DV10X3 MK2 , One channel sometimes go soft,  but a tap brings it in. Mafioso , could have a look to see if can be fixed.
dynavector ruby very old , but legend  One channel not working. Mafioso , could have a look to see if can be fixed.
ortofon kontrapunkt A MC In full working order
DUAL 1019 With SHURE M44MG cart.
NOS, used once.
box and papers still there.
with spare 1019
motor not turning, suspect service required on bush perhaps.
all auto functions working
Citronic AC-1USB New, never used. With audacity software
PC recording of analogue or aux inputs(LP, TAPE, CD, etc..)
drivers mainly vintage drivers?
notable ones are philips 9710m  - perfect condition
phillips ad12100 m8 - one had a small tear but paper fix applied with help from forum was good, sound intact
goodmans axiom201 - one is good, the other is patched badly, but they both play well
complete internals for one infinity refference RS3A incl XO and two woofers.
some 4 philips ad8080(2 in perfect condition)
2 stentorians  , one with a tear, but sounds good(ugly patch work).
2 x fullrange drivers (no name, came with philips ad12100 m8's)
cabs SABC monitor cabs , housed the phillips 9710m, REAL WOOD, kept as is for nostalgia? :)
Williamsons mono - serviced by Alan and working fine, just need a new valve or two. (3 parts,,one old preamp with shellac type filters, nice power supply with big partridge trafos and nice power section(el34 based)). with williamson manual which contains this circuit which I got from Alan.
tx
KJS
