hi guys,
was wondering if anyone here would be able to help me with this problem i have.
a marantz 3300 preamp with a very weak left channel.
i have done some reading up online and most who experienced a similar problem have said that that deoxit spray thingy helped them.
i managed to get a can at electronics 123 but didnt help
any suggestions?
i can remedy the symptoms with a graphic equalizer with +10dB on the weak channel and around -8dB on normal channel. that will give you an idea of the severity. with this 10 dB gain comes a faint, but audible 1KHz buzz.
thanks in advance
dolt
any suggestions?
thanks in advance
dolt
