I want to display a DSTV signal on a Samsung P2350 monitor? The signal will be tranmitted from my DSTV decoder in lounge to my bedroom wirelessly using the Ellies AV sender which I already have. Tonly has composite video output.
The monitor has the ffg inputs -
Connector : 15pin D-SUB, DVI-D
Sync. Signal : Separate H/V, Composite, SOG
Video Signal : Analog RGB, DVI
What can I use to connect the composite video output to this monitor?
