How-to-Clean-and-Fine-Tune-a-Tape-Deck
Status
Not open for further replies.
Prince
Southern Burbs, Cape Town
Courtesy: http://www.hardwaresecrets.com
http://www.hardwaresecrets.com/article/How-to-Clean-and-Fine-Tune-a-Tape-Deck/1578
Introduction
Before we can teach you how to connect a tape deck to your PC in order for you to convert your old cassette tapes into MP3 files or CDs, we need to teach you how to clean and fine-tune it, so you will get the best audio quality. Let?s get down to it.
The tools you will need are a few cotton swabs (?Q-tips?), alcohol (isopropyl is the recommended kind), and a small (i.e., number one) Philips screwdriver for the azimuth adjustment.
In Figure 1, you can see the tape deck we are going to use in this tutorial. If your equipment has two decks like ours, you have to decide if you want to clean both decks or only the one you are going to actually use to play the tapes. In our case, we decided to clean only the right-side deck, so the pictures will reflect this choice.
8)
Status
