HUAWEI B 618 HELP
mantloko
Kokstad
Can anyone help? I have a new Huawei B618 router. It worked for a few weeks now all 3 of the top green lights go off and I get disconnected for a few minutes then re-connected.
I thought it was Cell C's fault as I have a 200Gig data contract with them. So I got another contract from MNT for the same amount as I was told Cell C were having problems in this area. However, exactly the same is happening with the MTN data sim. On and off.
Is my router faulty? I have tried everything I know from re-booting to re-setting. Nothing helps. My Fingbox also goes off when not connected. It's very frustrating. The signal in this area is very strong as can be born out by my cell phone's (MTN & Cell C)
signal strength. I have an expensive antenna rigged up. Nothing helps. I have to connect now using my cell c phone as a hot spot but obviously no wi fi in the rest of the house. Any suggestions would be of great help.
