Lan to Wifi
Status
Not open for further replies.
Anton
Pretoria
Hi All ...
I have a Old-ish receiver that i want to use with Spotify via Wifi
The problem is the wifi is not working anymore on the receiver , but the Lan port is working
so is there a way to take the lan to a external wifi router and use the router as the receiver's wifi ?
Where i want to put the amp i cannot use lan cable so i want to use the wifi
Thank you
Status
