I'm playing with the idea of adding a MiniDSP to my surround setup, I'm not sure about the input impedance though - preouts output 4.5Vrms whereas the MiniDSP's inputs are either 0.9 or 2Vrms?
Also, what would you think the optimal setup would be if used in conjunction with Audyssey - EQ subs individually with MiniDSP then run XT32 or run XT32 then EQ subs summed with MiniDSP?
