Hi all.
Need help to cut a few MDF boards to spec.
Would like to cut as per below pic.
I have also not bought the MDF yet.
I can do it ,,, Just , time is so little and would like to do tests as soon as possible.
I would like to have exact same cuts. But with 16" centre hole and another 16" hole on top of that one ... A bit off centre for both.
and then three sets of those rings to mount the drivers on ( one for 15" and one for 16" and one 16" round wood plate to close the hole)...
Would be nice if those rings could be a bit profiled on the edges to give a sunken sort of effect as opposed to straight...
Any idea where I can go and what a reasonable cost should be ?
My hand tools just take too long for my liking .
Much appreciated.
Much appreciated.
