I write this as what I discovered the last few days may be useful for the board's diy'ers.
I model builder friend asked me a few days ago to nickel plate some brass stanchions he made for a loco tender.
I agreed as I had nickel electrolyte in my workshop together with all the rest of the paraphernalia to do the job.
After preparing the little brass objects for plating, I discovered that the commercially-made nickel electrolyte had become unfit for use as I last used it 15 years ago.
So I googled a bit and found a 'recipe' on how to make your own electrolyte.
All you need is a bottle of white vinegar, a teaspoon of salt and a teaspoon of sugar. The salt is for improved conductivity and the sugar acts as a brightener during the plating process.
Besides the vinegar and its ingredients, you will require a bench powersupply of say 30Vdc rated at 3 to 5amp,
and two pieces odf nickel to act as anode and cathode.
The powersupply's + is connected to one piece of nickel and the - to the other nickel piece.
The process of making nickel electrolyte will take about 3 to four hours or until the vinegar turns green.
Once this process is complete, the item you want to nickel plate is attached to the - of your power supply and the + to the nickel cathode.
There are lots more involved like ensuring total cleanliness of whatever you'd like to plate and perfect connection of the current.
And it worked.
mafioso
And it worked.
mafioso
