I recently installed one of these in my system. It's only about the size of a 30cm-a-side cube, but man, does this little subwoofer perform! It sounds and feels like a much larger sub. The summary of the Secrets of Home Theater and Hi Fidelity review sums it up much better than I can:
It's not cheap, but if you don't want a big box in your living room or home theater due to space or aesthetic reasons then this will give you the same performance in a much smaller package.
See the reviews and measurements below:
http://www.hometheaterhifi.com/subwoofers-products-menu-column1-41/1021-paradigm-reference-seismic-110-subwoofer.html?showall=1
http://www.avforums.com/review/Paradigm-Seismic-110-Subwoofer-Review.html
The Paradigm Seismic 110 subwoofer is a freak. It is very small, lightweight as subwoofers go; yet capable of playing very loud, very low, and very clean. It will blow away subwoofers that are bigger, heavier, and in some cases, more expensive. Highly recommended!
