QUAD 303 - "Motorboat Effect" - Solution?
G
Gliding Dutchman
Guest
I have a QUAD 303 power amp.
It is sounding very good and performs well. All capacitors has been replaced a year or two ago.
There is one problem:
When I turn it one the left channel will cause the speaker to pump erratically for the first 5 to 8 minutes and then it will settle. This errattic output corresponds to almost 20 volts on the DMM!
What would be the cause of this?
Danke,
GD
