Recommendations for long cable run - REL subwoofer high level Neutrik Speakon connection
RRankin
North West Province
I am going to need to extent my neutrik speakon connections to +-10 meter each for my set of REL Strata's to allow use in the back corners of the room.
The Neutrik speakon connections use 3-wires (two wires sufficient if a sub is used dedicated per channel, but this may change so I'd like to keep the connections universal).
What would you recommend as a good choice of cable, commercially available? If one considers that the standard REL Neutrik cable is a very simple unshielded 3-core arrangement, I am certainly not thinking to go for exotic stuff, don't see the need and offcourse pricing will be terrible. With that said, over long runs some form of shield may be beneficial (asking?), it will run past some other electrical wires in the process.
Thanks in advance.
