Reflex port with corner question.
Crankshaft
I would like to build a pair of cabs for Goodmans Axiom 80 drivers.
Will be based on the following:
I will keep the internal volume the same, but the shape of the cabs will be changed.
My question relates to the ports.  The port in the original drawing has a 90 degree bend, and is also quite close to the driver.
How would I alter the port length if it is to be straight?
I imagine that the reason the port is like this is do that it does not extend too far into the rear corner of the triangular cabinet.
Perhaps I'm better off with a rear-loaded horn.
