Replacing RCA connectors
cuthza
Western Cape
My Technics SL-23 turntable right channel RCA connector has an issue. It is scratchy sounding and I can only get it to work when I turn and wiggle it, and then it keeps messing up again.
I want to replace the RCA connectors on the end of the cable as I think this will solve the issue. Is there any specific connector I should get? It seems that chopping off the connectors and replacing them will be the simplest solution - is this true?
Perhaps replacing the whole cable would be better but it seems a bit complicated from what I've read and you have to be very careful not to snap tonrarm wires etc. I don't know if I feel comfortable with that. Alternatively, I could take it to someone to do this, but it would be easier if I could do it myself.
