The 2HP-D outputs 600Wpc RMS into 8 ohms, 20Hz?20kHz (<0.01% THD), or 1200Wpc into 4 or 2 ohms. At 1kHz, 0.01% THD, it outputs 746Wpc, or one horsepower, hence the model name: 2HP-D. The 2HP-D's distortion figures (see "Specifications") are extremely low, and vary very little at either 10W or at rated power. The bandwidth is wide (+0/?3dB, 5Hz?150kHz, into 8 ohms), the slew rate fast (>60V/?s), and the signal/noise ratio high: 128dB ref. rated output, A-weighted.
Read more at http://www.stereophile.com/content/sae-2hp-d-power-amplifier#VHskvLqmGY0MoQ41.99
JIP!! 2 power cords for this girl!!!
