Good day,
I have a samsung UA46F8000AT tv and cannot find the screw sizes for the TV bracket.
The tv has two holes that fit the normal size screws and then there are two holes (with plugs) further up that are smaller than the ones below.
Does/did anyone have this tv and use a tv bracket with it?
