SOHA II Headphone Amplifier Build
shadow.clone
Durban / Pretoria
Hi guys,
This thread will cover my SOHA II headphone amplifier build. I'm using veroboard instead of the official PCB so progress is a bit slow.
I decided to start this project after I was given unused electronic components and old equipment. Everything from the case, 12AU7 valves, screw terminal connectors, nuts, bolts, washers, thermal pads, wire, some capacitors, LEDS and heatsinks will be reused.
SOHA II website: http://www.cavalliaudio.com/diy/soha%20ii/main.php?page=overview
shadow.clone
