Speaker grille / PC fan guard
chipwelder
Tshwane
Hi I'm looking for ca. 200mm versions of these - drivers diagonal bolts are spaced 170mm - will bend arms for standoff... must have four connection arms, as my mid-woofs are bolted with four bolts... Preferably in South Africa... I don't seem to get ones larger than 120mm So if any of you computer boffs know of a supplier I will greatly appreciate it.
http://www.alibaba.com/product-gs/432628242/Computer_fan_grill.html
