Speaker loads , pls help.
King_Julian_S
Jhb Alberton
:walled:
Ok , pls help.
So assuming my amp is 8 ohms.
I really want to connect a set of 8 ohms and 15 ohms together.
The amp is a push pull valve amp so apparently valves does not make a diff in terms of wattage/power.
So my understanding is as follows...
if you connect a 15 + 8 ohm in parallel that you will have a 5.2 ohm load.
Is that correct ?
(15x8) / (15 + 8) .
So will this necessarily be bad ?
Here is another interesting topic I found.
Could I do this ?
TECH TIP -- If you can 'stand' wasting a little power, here's how to use 8-ohm and 16-ohm speakers together:
a) place an 8-ohm/high-wattage "power dropping" resistor in series with the 8-ohm speaker...thus making it "look" like a 16-ohm load.
b) connect the 16-ohm speaker in parallel with the series-connected 8-ohm speaker-plus-8-ohm dropping resistor...thus making a total combination load of 8-ohms.
c) the volume from both speakers should be approximately equal!
try a weber silencer load. works very well for me
11-03-2006, 08:23 AM
Wouldn't this effect the impedance the tubes will see a cross the freq range?
Meaning a single 16ohm speaker vs. 8ohm speaker + 8ohm resistor.
Well I need a trick like that but the other way around, turning a 16ohm speaker to an 8ohm:)
Will a parallel resistor do the trick
