Streamers and Digital EQ
joffieb
Hi All,
I am looking for a little bit of inside advice from someone who knows how these things work. I have a very basic streamer (the WiiM Mini), which has garnered rave reviews because it is bit perfect into a DAC. So even though it costs $100, if paired with a decent DAC, it punches well above its weight. They are however introducing a customisable 10 band EQ feature which I would love to utilise with REW. I am worried however, that by turning on the feature, it will degrade the quality of the file being sent to the DAC. As I am unaware how digital EQ works, for example like DIRAC, I would like to know if the component doing the EQ actually changes the content of the music file it is playing or if it adds a sort of tag that tells the DAC just to EQ the original file? If the latter, the EQ feature shouldn't downgrade sound quality too much.
Any advice would oblige.
Thanks!!
