Stylus cleaning with Magic Eraser.
Waterhond
R.I.P. August 2020
Cape
Hi-Phibean alerted to the use of so called Magic Eraser for cleaning your stylus sometime last year:
Hi-Phibian said:
...google "magic eraser stylus cleaner" and then look for the 3M equivalent called easy erasing pads or any special magic cleaner sponge that says it is made from melamine foam.
Forget the onzo goop, the migrating liquids etc, just dunk in to the DRY magic eraser sponge.
Found these made by Addis at my local Spar today - two in a packet for R12.49 - should last a long time if used for cleaning styli only!
Instructions for use:
http://www.high-endaudio.com/Magic.html
and:
http://www.avforums.com/forums/hi-fi-systems-separates/928129-magic-eraser-stylus-cleaner.html
Please do not clean your TV or PC screen with this - it's quite abrasive on a microscopic level apparently!
