Subwoofer box build help.
CAD
East Rand
Seeing Bizkits coffe table subwoofer box I decided persue a brain fart I had some time ago.
I had a side coffe table/box in mind made from pine or mdf so that I can stain it the same as my other tables.
My thinking is either 1 X 15" or 2 X 12" subs firing downwards.Box size 600x600X400 or there about with 100mm feet.
Does this look right?
Can I then use 1 or 2 std 4" ports?
I assume I would need internal bracing too.
