Tape Gear for NAD 616
Audiofundi
Hi
Hoping for some help on a peculiar issue.
Have a NAD 616 double tape deck which has a noisy forward and rewind on one side. Opening by tech guy shows a wheel that has a small split. It is very atypical with 23 very long teeth, outer diameter 10mm with a shaft diameter 2mm.
What can be done about this ? Any experience of a similar problem that was solved or perhaps where to find this wheel as per pic. There are some pics but it is the one in the middle of the first pic and then a less closeup pic as well
Any input will be appreciated, thanking you in advance
