There are repairers, and there are repairers
chrisc
Plumstead, Cape Town
Had a MacBook Pro since 2013.  For the last few months, it has been sluggish and/or need a bit of nudging to wake up from sleep (closing the lid).  I went through all the advice given by fundis and Apple forums alike.  Some days it would spring to life when you open the lid, other times it needed 2 or 3 pushes on the power button.  I reset the SMC and also the NVRAM to no avail.  The power settings are set to never sleep
About a month ago it would just not wake up.  So I took it along to Digicape for some advice.  Their advice, given after 15 mins was that they would replace the logic board for R 13300,00
Not wanting to take such drastic a step, I took it to Laptopfix in Old Stanhope Road.  He undid the base cover, disconnected the battery lead, waited 2 mins and put it back.  The computer woke up immediately.  They were not going to charge since I push a lot of work their way, but gave the fellow R 500 for his trouble.  In and out the shop in 20 mins
So I called this fellow at Digicape.  His initial response was that I was talking rubbish, it cannot happen like that, he said.  He then admitted that the battery story can often fix a sleep problem, but this practice is frowned upon by Apple since it does not generate "faith" in Apple products.  Maybe faith is a euphemism for more repair fees.  Looking on several Apple forums, removing the battery is a recommended fix and many readers confirm that it works, and the machine continues to behave thereafter
