triode/thermionic vacuum tube/valve shelf life?
keithp
Richards Bay
Hello Gents,
Had an interesting question from a new generation thinker today; if one installs a new set of triode's just for the sake of testing them then placing them back into storage, what is this shelf life?
(should be the same as NIB? - devices have already been 'soaked/tested' after production then further voltage applied to match in sets.)
Abstract: Low power triodes have a concentric construction (see drawing right), with the grid and anode as circular or oval cylinders surrounding the cathode. The cathode is a narrow metal tube down the center. Inside the cathode is a filament called the "heater" consisting of a narrow strip of high resistance tungsten wire, which heats the cathode red-hot (800 - 1000 °C). This type is called an "indirectly heated cathode". The cathode is coated with a mixture of alkaline earth oxides such as calcium and thorium oxide which reduces its work function so it produces more electrons. The grid is constructed of a helix or screen of thin wires surrounding the cathode. The anode is a cylinder or rectangular box of sheet metal surrounding the grid. It is blackened to radiate heat and is often equipped with heat-radiating fins. The electrons travel in a radial direction, from cathode through the grid to the anode. The elements are held in position by mica or ceramic insulators and are supported by stiff wires attached to the base, where the electrodes are brought out to connecting pins. A "getter", a small amount of shiny barium metal evaporated onto the inside of the glass, helps maintain the vacuum by absorbing gas released in the tube over time.
    56.4 KB
