Unifi Play Power Amp
XL1000
Roodekrans
I came across this new streaming Amp from Unifi. They look well-specked, and I hope they will apply for Roon Certification in time.
For those of you into Networking and Unifi in particular, they have made a few significant improvements and added QoS to Audio Video streams over their networks, using the latest switches.
https://ui.com/new-integrations/premium-audio
The UniFi Play is a state-of-the-art audio amplifier designed for both home and professional use, delivering exceptional sound quality and versatility. With a robust Class D amplifier architecture, it provides continuous power output of 130 W at 8 Ω and 260 W at 4 Ω, ensuring that your audio experience is rich and immersive. The device supports a wide range of surround formats, including Dolby Atmos and Dolby TrueHD, making it an ideal choice for audiophiles and casual listeners alike. Its sleek design is available in black and white colors, allowing it to blend into any environment seamlessly.
Equipped with advanced connectivity options, the UniFi Play features two GbE RJ45 ports and supports WiFi standards up to 802.11 a/b/g/n/ac. This ensures a stable and high-speed connection for streaming audio from various sources. The device is designed for desktop mounting and operates efficiently with a power consumption of just 17W. The integrated 1.43" rotary knob with touchscreen provides intuitive control, while the LED ring adds a modern touch to its functionality.
With the ability to group up to 32 PowerAmps, the UniFi Play is perfect for larger setups, allowing for a scalable audio solution that can adapt to your needs. It also includes multiple audio inputs, such as HDMI eARC and RCA analog inputs, ensuring compatibility with various devices. The amplifier is certified by FCC, IC, and CE, guaranteeing its reliability and performance. Whether you're setting up a home theater or enhancing your professional audio system, the UniFi Play stands out as a powerful and versatile choice.
