user 20430
- Joined
- Dec 28, 2017
- Messages
- 15
- Reaction score
- 3
Hi everyone,
I?d like to ask for some guidance to troubleshoot a VA Exclame that won?t switch on.
When the unit is plugged in, I can see the valve glowing however it won?t switch on. I have checked the fuse which seems to be fine and tested a few power cables, which haven?t rectified the issue.
Is there anything else that I should check? Or would it be best to contact Valve Audio?
Thank you...
SM
Thank you...
SM
