Valve pre from Rudi
soundadv
Centurion ,Gauteng
So i started the build last week some time,first i made a small setup just to check it out,and i liked it from the start,
ran it the hole weekend like this with the back angle removed from the rest for isolation reasons,connected to the Emotiva amp.
The gain is a bit on the hi side but that can be sorted,the remote and input selector works 100%.
have started to machine the enclosure ,i will ad some pics.
    70.4 KB
